SD tester je open source projekt s katerim lahko preverite ce vase SD kartice delujejo pravilno. Ob nepravilnosti se pojavi kratek pok,beli sum +- 0.05dB pa je normalen.
Tester je narejen v arduino okolju,za to potrebujete knjiznice in sicer:
adafruit SSD1306 128x32 I2C (Adafruit_SSD1306.h)
dfplayer Library (DFRobotDFPlayerMini.h)
kako nalozite knjiznice najdete tukaj:
https://learn.adafruit.com/mon…/arduino ... d-examples
Na tej strani najdete datoteke,ki jih potrebujete za izdelavo testerja:
www.audiologs.com/SD-audio-tester/SD-tester-audio.ino
Primer napake SD kartice (rahel pok):
www.audiologs.com/SD-audio-tester/Audio ... SDcard.jpg
audiologs.com/SD-audio-tester/AudioTestErrorSDcard-I.jpg
in avdio napaka:
www.audiologs.com/SD-audio-tester/SD256 ... wLevel.mp3
shema:
www.audiologs.com/SD-audio-tester/Mp3-SD-tester.jpg
za download (vsebuje eagle nacrt *.sch in bmp datoteke):
www.audiologs.com/SD-audio-tester/SD-card-tester.zip
Za avdio analizo si lahko pomagate z brezplačnim programom Audacity:
https://www.audacityteam.org/download/
lp
